We’ve just released FreeCAD 1.0rc2, builds are already avail­able for down­load­ing on GitHub. The update is com­ing with just bugfixes.
The num­ber of issues block­ing the final release has been cir­cling around 6–8 for the past few weeks and only went as high as 13 after we released rc1. We are cur­rent­ly at just 8 blockers.
Unless there’s a lot of issues that haven’t been pre­vi­ous­ly uncov­ered by every­one who already test­ed the pro­gram, we think we can man­age to fin­ish off the rest of the block­ers in a cou­ple of weeks. The impor­tant thing is to fix and close new reports faster than they appear.
We’d be real­ly grate­ful for test­ing rc2 and report­ing bugs you run into, espe­cial­ly the crit­i­cal ones like crash­es and regres­sions (e.g. things that used to work before and now don’t work anymore).
14 responses to “The second release candidate of FreeCAD 1.0 is out”
  1. Marcus Avatar
    Marcus
    This is not a release can­di­date, but a beta. If there are block­ers that need fix­ing before the final release then it’s not a release can­di­date, by def­i­n­i­tion. How can it be a can­di­date for the final release if it’s known that it can’t pos­si­bly be a final release because of block­ers? Just call the beta a beta. It’s great to have a release, regard­less of the name, so there is no need to mis­name it.
    1. MickeyMouse Avatar
      MickeyMouse
      I think the release should be called Robbie.
      1. Marcus Avatar
        Marcus
        Sure, and its name could be, say, Nick. But yes, I’m wrong in mis­nam­ing the state cat­e­go­ry as “name”. So, let’s agree that Nick (called Rob­bie), has the state cat­e­go­ry “beta” rather than “release can­di­date”, as Rob­bie there isn’t real­ly a can­di­date for a final release, ok?
  2. Jonah Avatar
    Jonah
    I had been putting off a few design projects until this 1.0 release. Excit­ed to final­ly get my hands on it. RC1 is already feel­ing much bet­ter! I think this is a great thing for Open Source Soft­ware and Lin­ux adop­tion, I know a lot of peo­ple who are locked into an oper­at­ing sys­tem and a prod­uct ecosys­tem due to their depen­dence on com­mer­cial draft­ing soft­ware. As you guys keep push­ing this clos­er and clos­er to a viable com­peti­tor with expen­sive sub­scrip­tion I think this will unlock a lot of peo­ple’s potential.
    Hap­py with the work of this team and excit­ed for the future of this project, keep it up!
    I will be con­tin­u­ing to donate to this project and I encour­age oth­ers to do the same if they have found this soft­ware lib­er­at­ing for design work.
    1. Marcus Avatar
      Marcus
      I’m actu­al­ly donat­ing to realthun­der’s FreeCAD, which is so very much nicer to use. I know main­line has some fea­tures that rt lack, but rt has so many very use­ful fea­tures that make it so much eas­i­er and faster to use, so at least for now my sup­port is going to rt. Maybe main­line could copy oth­er use­ful fea­tures from rt now that they’ve fin­ished copy­ing the main TNP stuff. Or maybe with some more dona­tions rt would copy some of the few fea­tures that are in main­line but not yet in rt. For now my dai­ly dri­ver will be rt, just because it’s so much nicer and faster to work with.
      1. Jonathan Avatar
        Jonathan
        Have you tried the week­ly builds, or this new release can­di­date? I know rt still his some advan­tages, but the main branch is pret­ty darn good these days.
      2. Marcus Avatar
        Marcus
        Yes, I’ve tried sev­er­al ver­sions, includ­ing both release “can­di­dates”. They’re extreme­ly frus­trat­ing to work with. I run into miss­ing fea­tures every minute while try­ing to work with them. I can’t even view objects prop­er­ly, since they lack a work­ing hid­den line view. Instead of being a com­bi­na­tion of Wire­frame and No Shad­ing it shows tons of opaque tri­an­gles. The way it works in realthun­der’s branch is way, way more use­ful than any view in main­line. And when you edit mod­els some ref­er­ences will always break. In realthun­der’s branch you can eas­i­ly and quick­ly fix bro­ken ref­er­ences (or change ref­er­ences), in main­line you have to re-cre­ate all of them, re-cre­at­ing con­straints, etc, which is insane­ly time-con­sum­ing. Already these 2 fea­tures makes main­line a no-go for me, because they 1) make it annoy­ing to cre­ate things, and 2) make it very annoy­ing to mod­i­fy things.
  3. steph5553 Avatar
    steph5553
    new assem­bly does­n’t work with fas­ten­ers workbench
    1. Aleksandr Prokudin Avatar
      Aleksandr Prokudin
      If you mean the inte­gra­tion like in Assem­bly 4, then no.
  4. […] the Ver­sion 1.0 release can­di­dates com­ing thick and fast it’s a good time to explore some of the new fea­tures that Ver­sion 1.0 will have to offer. One […]
  5. Erich Avatar
    Erich
    I am fol­low­ing the devel­op­ment of Freecad 1.0 very close­ly. When work­ing with ver­sion 1.0rc1 I was thrilled by the new fea­tures. I hope that the bugs of ver­sion 1.0 can be fixed quick­ly and that there will be an offi­cial release. At the moment, ver­sion 1.0 can­not yet be used for com­mer­cial appli­ca­tions. That is my per­son­al impression.
    I would like to thank the large devel­op­er com­mu­ni­ty for the imple­men­ta­tion and fur­ther devel­op­ment of FreeCAD. It’s going in the right direction.
    Keep it up, thank you.
  6. Gerd Avatar
    Gerd
    I am run­ning FreeCad beta 2 on Ubun­tu 24.04, installed as a snap file and still don’t see the minia­ture project icons on the FreeCad start screen. See screen­shot at https://www.dropbox.com/scl/fi/gbtsoi5baa1oennlol8n6/Bildschirmfoto-vom-2024–10-02–14-57–52.png?rlkey=z5rzskush7nb5zfyzhhzmizns&st=7aqhfuoz&dl=0
    1. Marcus Avatar
      Marcus
      Have you enabled Edit->Preferences->General->Document->Save thumb­nail into project file when sav­ing document?
    2. furgo Avatar
      furgo
      That’s issue https://github.com/FreeCAD/FreeCAD/issues/13676 — feel free to com­ment there too
Continue reading
