It’s fair to say FreeCAD has a lot of tools and fea­tures and it’s com­mon to focus on learn­ing the tools that help you realise your designs. As such it’s also com­mon to miss fea­tures that have been avail­able in FreeCAD for quite some time. It’s notice­able online some­times that peo­ple often post small video screen cap­tures of their projects with the project pre­view revolv­ing. Often you then see ques­tions or com­ments on “how do you animate/revolve your part like that?”
The turntable tool is avail­able from every work­bench in FreeCAD and can be found by click­ing “Tools – View Turntable…”. When you select the tool a small dia­logue appears where you can set the speed of rota­tion and also the angle of rota­tion. You can also set a timer and also enable full screen. Once you have cre­at­ed your set­tings you sim­ple click the “play” but­ton to start the turntable rotation.
One thing of note is that the view of your project in the pre­view win­dow influ­ences the posi­tion of the ani­ma­tion. So if your pre­view win­dow has your part or project off to one side the rota­tion will be tran­scribed around a larg­er arc than if your part or project is in the cen­tre of the pre­view pane.
Final­ly, not part of FreeCAD, but the final part of the puz­zle for cre­at­ing sim­ple rotat­ing ani­ma­tion clips to show off your project online is to grab a screen record­ing appli­ca­tion for your oper­at­ing sys­tem. There are lots out there regard­less of your oper­at­ing system.
3 responses to “Tutorial: Using the Turntable Function”
  1. edragos Avatar
    edragos
    The Turntable tool is indeed very nice.
    But I hope that in the futures improve­ments of FreeCad to exist a but­ton like “OK” or “Save” in Tex­ture map­ping tool for those users who want to make tex­ture permanent.
    This will be very nice.
    Hap­py New Year to everybody.
  2. JanW Avatar
    JanW
    I love “Screen­ToGif” for record­ing to .gif or many oth­er video for­mats. Easy to use, com­plete­ly free. Unfor­tu­nate­ly it’s Win­dows only.
    1. Ivan Tarozzi Avatar
      Ivan Tarozzi
      late­ly i use kiiha in lin­ux. It records screen as both mp4 video and ani­mat­ed gif https://github.com/SeaDve/Kooha
Continue reading
