Q2 2025 grant program deadline
This year, we are run­ning the grant pro­gram in four waves. The dead­line for sub­mis­sions in the sec­ond wave is quick­ly approach­ing. We will wrap up on June 1, so if you are con­sid­er­ing par­tic­i­pa­tion and you have a great project in mind, please sub­mit your appli­ca­tion before that. Oth­er­wise, it will be reviewed in the third wave.
For pro­gram rules and guide­lines, please see this page.
5 responses to “Q2 2025 grant program deadline”
  1. Usuario Avatar
    Usuario
    Trans­lat­ed from Spanish.
    Hel­lo,
    Thank you for FreeCAD, it is a great application.
    Although I know this is not the right place I respect­ful­ly allow myself to com­ment that sketch­er work­bench is bro­ken since ver­sion after 1.1.0dev.39416, in this case the Trim edge tool does not work as expected.
    I am very clear that ver­sion 1.1.0dev is cur­rent­ly a devel­op­ment ver­sion and it is expect­ed that these things can hap­pen, how­ev­er, con­sid­er­ing that sketch­er work­bench can be used by oth­er work­bench­es and that the trim edge tool is crit­i­cal, it seems impor­tant to me that this bug/report got more attention.
    Since ver­sions after ver­sion 1.1.0dev.39416 can­not be used, the new fea­tures that have been added can­not be test­ed and pos­si­ble bugs can­not be identified.
    https://www.youtube.com/watch?v=rBE1Ys78BOE
    https://www.youtube.com/watch?v=R__tjRKDDrw
    It is worth men­tion­ing that there are many sim­i­lar bugs report­ed that are relat­ed to the sketch­er work­bench trim edge tool from around the same time.
    For exam­ple:
    https://github.com/FreeCAD/FreeCAD/issues/18497
    https://forum.freecad.org/viewtopic.php?style=8&t=93858
    https://github.com/FreeCAD/FreeCAD/issues/19425
    https://www.reddit.com/r/FreeCAD/comments/1k3ph28/trim_crash_still_not_fixed/?rdt=37238
    Best regards
    1. Aleksandr Prokudin Avatar
      Aleksandr Prokudin
      Hi, it’s dif­fi­cult to track issues post­ed else­where. Could you please file a bug report at https://github.com/FreeCAD/FreeCAD/issues?
  2. Pepito Avatar
    Pepito
    Hel­lo,
    Sketch­er work­bench is broken.
    Trim edge does not work properly.
    Thank you for mak­ing FreeCAD bet­ter every day.
    Best regards.
      Aleksandr Prokudin
      Hi, the Trim tool was patched recent­ly to fix var­i­ous issues. if you are on week­lies, please make sure you run the lat­est build. If you run the lat­est and great­est and you still have issues with trim­ming, please sub­mit a report to https://github.com/FreeCAD/FreeCAD/issues. That will make it eas­i­er to track and fix the spe­cif­ic issues you’ve run into.
      1. Pepito Avatar
        Pepito
        Hel­lo Aleksandr,
        Thank you for your response.
        Yes, I am using the lat­est build.
        Unfor­tu­nate­ly I don’t have a github account.
        Best regards.
Continue reading
