Draft:
  • tetek­toza patched the Poly­gon tool to show a real shape pre­view rather than a gener­ic cir­cle when adding a poly­gon to the draft.
  • Var­i­ous fix­es from Roy_043, tetek­toza, and furgo16.
CAM:
  • tarman3 made the new CAM sim­u­la­tor to show the doc­u­ment name in the win­dow title. They also added a but­ton to decrease sim­u­la­tion speed, changed the list of speed val­ues from [1, 10, 40] to [1, 5, 10, 25, 40], and improved cam­era zoom limits.
  • Var­i­ous fix­es from jffmichi, dbtayl, Lar­ry­Woest­man, tarman3, davidg­ilka­uf­man, and otwieracz.
BIM:
  • paullee0 con­tin­ued adding sup­port for the ArchS­ketch add-on.
  • tetek­toza added a but­ton for the BIM Views sub­menu to acti­vate a work­ing plane of the select­ed item. He also made it pos­si­ble to change the Sill para­me­ter once a Win­dow object has already been created.
  • Var­i­ous fix­es by furgo16, mar­cus­pol­lio, Roy_043, tetek­toza, and paullee0.
FEM:
  • marioalexis84 imple­ment­ed solv­ing elec­tro­sta­t­ic sys­tems with Cal­culiX by anal­o­gy with the steady-state heat equation.
  • NewJok­er and ick­by fixed sev­er­al issues.
Tech­Draw:
  • chennes fixed a hatch size con­straint intro­duced by an ear­li­er patch.
  • Wan­der­erFan made it pos­si­ble for non-shape views (Sym­bols, DraftView, BIMView, etc.) to have children.
Mate­ri­als: tri­a­to and chennes fixed a cou­ple of issues.
Addi­tion­al improve­ments and fix­es were con­tributed by theo-vt, Rayno­Jiang, sasobadov­inac, Syres916, chennes, ours­land, tri­tao, fil­ip­por, 3x380V, pieter­hi­j­ma, xtemp09, kadet1090, benj5378, and mosfet80.
PR stats: since the pre­vi­ous report, 71 pull requests have been merged, and 34 new pull requests have been opened.
Issue stats: over­all, there are 2852 open issues in the track­er, up by 12 from last week.
4 responses to “WIP Wednesday, 14 May 2025”
  1. Joe Beach Avatar
    Joe Beach
    Thank you for pro­vid­ing these week­ly updates, Alek­san­dr. It is great to hear about the work the devel­op­ers are doing.
    And thank you to the devel­op­ers for their work!
    Joe
  2. Stefan Hertweck Avatar
    Stefan Hertweck
    I like the newslat­ter. It pro­vides info on recent changes and gives kudos to the peo­ple that actu­al­ly made it happen.
  3. mechanic Avatar
    mechanic
    Some­one greased the FC merge machine?
    1. Aleksandr Prokudin Avatar
      Aleksandr Prokudin
      Very much so 🙂
Continue reading
