Let’s talk about the 2025 FPA grant pro­gram: what projects were vot­ed for, what projects weren’t, and what we think needs to change for this year’s program.
2025 grants
Last year, we got 46 grant appli­ca­tions. We vot­ed ‘yes’ on 31 of them and ‘no’ on 15. Here is a quick explainer:
  • Q1, Q2, Q3, and Q4 are quar­ters of the year
  • declined: grant appli­ca­tions that weren’t vot­ed for
  • OO: grant appli­ca­tions for the sep­a­rate Ond­sel Onwards fund
#Grant TitleSub­mit­terLabelsBud­get
23Refac­tor­ing Sketch­er 2AjinkyaDa­haleQ14000 EUR
24Improve FreeCAD Copy Paste system.Pad­dle­Strokedeclined4000 EUR
25Tech­Draw: New PagePad­dle­Strokedeclined4000 EUR
26Tech­Draw: rework anno­ta­tion toolsPad­dle­Strokedeclined6000 EUR
27FreeCAD Road WorkbenchHakanSeven12declined10000 EUR
28home­brew-freecad fix build­ing a mac app bun­dle using deps based around homebrewipatchQ11000 EUR
29[Lens] Make Lens Plat­form Self-Deploy­able and Cloud-Agnosticamrit3701Q1, OO6500 USD
31Con­cept for ISO GPS imple­men­ta­tion “3D Anno­ta­tion and Tol­er­anc­ing WBmaxwxyzdeclined9000 EUR
32Reor­ga­ni­za­tion of the FreeCAD UI — WBs and toolsFran­cis­co-Rosadeclined7000 USD
33New curves for SketcherAjinkyaDa­haleQ16000 EUR
34Main­te­nance, improve­ment and devel­op­ment of new fea­tures on the FEM workbenchmarioalexis84Q13000 EUR
35Mod­ern­iz­ing FreeCAD’s Ren­der­ing and Selec­tion Systemstri­taoQ14000 EUR
36Mul­ti­thread­ing Archi­tec­ture Improve­ments in FreeCADtri­taoQ12000 EUR
38Pat­tern tools refac­tor, uni­fi­ca­tion and addi­tion­al functionality.Pad­dle­StrokeQ22000 EUR
39Con­fig­u­ra­tion Space Visu­al­iza­tion for Com­put­er-Aid­ed Geo­met­ric Designbehol­lis­terQ2500 USD
40Web­sites improve­ments ini­tia­tive — Step 1mar­cus­pol­lioQ24000 EUR
41Part­De­sign: Extrude Two directionsPad­dle­StrokeQ2500 EUR
42Main­te­nance, improve­ment and devel­op­ment of new fea­tures on the Assem­bly workbenchPad­dle­StrokeQ23000 EUR
43Main­te­nance, improve­ment and devel­op­ment of new fea­tures on the Sketch­er workbenchPad­dle­StrokeQ23000 EUR
44CAM/BIM: 2D Nest­ing Tool for FreeCADAbhi­ram­Mas­naQ2150000 INR
45Research ISO GPS / GD&T for an over­all con­cept as imple­men­ta­tion in FreeCADmaxwxyzQ23000 EUR
46CAM improve­ments for machin­ing metalsdavidg­ilka­uf­manQ23500 USD
47Assem­bly Solver Inter­face Abstrac­tion and Alter­na­tive Solver Implementationours­landQ22000 USD
48Update OSH Auto­mat­ed Doc­u­men­ta­tion for FreeCAD 1.0pieter­hi­j­maQ22000 EUR
50Pro­mot­ing Aca­d­e­m­ic and Edu­ca­tion­al use of FreeCAD via tar­get­ed writ­ten tutorialscon­crete­dogQ32000 GBP
51Main­te­nance, improve­ment and devel­op­ment of new fea­tures on the Assem­bly work­bench — Q3Pad­dle­StrokeQ33000 EUR
52Main­te­nance, improve­ment and devel­op­ment of new fea­tures on the Sketch­er work­bench — Q3Pad­dle­StrokeQ33000 EUR
53Tech­Draw: Rework anno­ta­tion tools — RepostPad­dle­StrokeQ32000 EUR
54Tech­Draw: New Page — RepostPad­dle­Strokedeclined2000 EUR
55Part­De­sign: Rev­o­lu­tion Two directionsPad­dle­Strokedeclined1800 EUR
58Design Sys­tem and Style Guidelineskadet1090Q35000 EUR
59Addons and Devel­op­ers Portalmne­sar­codeclined8000 USD
60[LENS] Enhanced Authen­ti­ca­tion, Brand­ing Cus­tomiza­tion, and Tru­e­NAS Inte­gra­tion for Lens Platformamrit3701Q3, OO12250 USD
61CAM improve­ments for the Adap­tive operationdavidg­ilka­uf­manQ34250 USD
62Sky domes, sun radi­a­tions analy­sis moduleFran­cis­co-RosaQ32000 USD
63FreeCAD video tutorialshowtofreecaddeclinedUnknown
64CNC Milling Machine Tutorialbkmgitdeclined1300 EUR
65Selec­tion sys­tem enhance­ments / overhaultetek­tozaQ43000 EUR
67Ond­sel Lens and Lens addon documentationprok­ou­dineQ4, OO1000 EUR
68Selec­tion Sys­tem Code Refactoringtetek­tozadeclined4000 EUR
69Selec­tion sys­tem enhance­ments / over­haul pt. 2tetek­tozadeclined3500 EUR
70Doc­u­ment Toponamingpieter­hi­j­madeclined8000 EUR
71Sun analy­sis, direct radi­a­tions and irra­di­ances analy­sis moduleFran­cis­co-Rosadeclined2000 EUR
72KiCon­nect PCB Work­bench [Time Com­mit­ment, Ecosystem]mor­gan­rallenQ45200 EUR
73Main­te­nance, improve­ment and devel­op­ment of new fea­tures on the Assem­bly work­bench — Q4Pad­dle­StrokeQ43000 EUR
74Main­te­nance, improve­ment and devel­op­ment of new fea­tures on the Sketch­er work­bench — Q4Pad­dle­StrokeQ43000 EUR
The aver­age grant request was approx­i­mate­ly EUR 3,650 with a medi­an of EUR 3,000, and a high­est request of EUR 10,500.
Here is the break­down by quar­ters, with con­ver­sion to EUR where applicable:
  • Q1: EUR 25,590
  • Q2: EUR 24,085
  • Q3: EUR 30,630
  • Q4: EUR 15,200
The total allo­cat­ed bud­get was EUR 95,505. Note that this includes EUR 17,125 drawn from the sep­a­rate, pri­vate­ly spon­sored Ond­sel Onwards fund, as opposed to the gen­er­al fund built from com­mu­ni­ty dona­tions. This makes the total bud­get allo­ca­tion under the planned EUR80K cap.
Grants completion
Out of 31 grants approved in 2025, work on 11 has been com­plet­ed. Please note that Q4 2025 grants were approved in mid-Decem­ber, so we expect­ed at least some of the work to be com­plet­ed in 2026.
For detailed infor­ma­tion on the sta­tus of approved grants, please see the respec­tive GitHub project man­aged by Reqre­fu­sion, the grant program’s com­mu­ni­ca­tion manager.
Program Analysis
The grant pro­gram was orig­i­nal­ly designed to serve two over­lap­ping purposes:
  1. Dis­trib­ute dona­tions to developers
  2. Encour­age devel­op­ment in spe­cif­ic areas iden­ti­fied by FPA members
To the extent that one of the pur­pos­es of the pro­gram is sim­ply to dis­trib­ute donor mon­ey to those work­ing on FreeCAD, the pro­gram suc­ceeds rea­son­ably well. 19 dif­fer­ent indi­vid­u­als received mon­ey through this pro­gram in 2025. It is not a per­fect way to dis­trib­ute the funds, but it is not unreasonable.
Regard­ing encour­ag­ing devel­op­ment in spe­cif­ic need-areas, how­ev­er, the pro­gram is much less successful.
With over two-thirds of grants fund­ed, we applied lit­tle “selec­tion pres­sure”. It was rare for either an FPA mem­ber or a grant review com­mit­tee mem­ber to vote to decline a grant on the basis of whether a pro­pos­al met some tar­get­ed need-area: most “no” votes were “val­ue for the money”-based, with a few com­ing on the basis of whether a giv­en fea­ture pro­pos­al rep­re­sent­ed some­thing we need­ed at all, not whether it fit into a larg­er plan, as well as some hes­i­ta­tion to fund out-of-core devel­op­ment work (e.g. addons).
Anoth­er prob­lem the grant pro­gram expe­ri­enced was a grant review team that pro­vid­ed very lit­tle feed­back. In many cas­es, review­ers pro­vid­ed sim­ple yes/no com­ments on grant appli­ca­tions. Fur­ther, even when pro­vid­ed with com­mit­tee feed­back, FPA vot­ers seemed to find lit­tle val­ue in it, instead form­ing their own opin­ions inde­pen­dent of any com­ment from the committee.
Recruit­ing review­ers also proved dif­fi­cult: despite sev­er­al vocal indi­vid­u­als on the forums express­ing opin­ions about how the FPA spends the grant mon­ey, none of those peo­ple vol­un­teered to serve on the committee.
2026 Program Modifications
Here is what we are like­ly to change for the 2026 program:
  1. The bud­get for the grant pro­gram should be reduced to EUR 40,000, divid­ed into EUR 10,000 quar­ter­ly grant rounds. The freed-up bud­get should be used for the bug boun­ty pro­gram and ongo­ing positions.
  2. The tech­ni­cal grant review com­mit­tee should be eliminated.
  3. The FPA should choose some small num­ber of action­able focus areas for each year’s pro­gram to help guide which appli­ca­tions should be select­ed (and vot­ers should take care to respect that selection).
  4. Grants should be lim­it­ed to one appli­ca­tion per devel­op­er per quarter.
  5. A “no” vote on a grant should require a state­ment from the vot­er about why they are vot­ing no, and that feed­back should be anonymized and pro­vid­ed to the grant appli­cant with the notice of their grant’s being declined for funding.
Leave a Reply
This site uses Akismet to reduce spam. Learn how your comment data is processed.
Continue reading
