This is a small announce­ment for who is using Git to work with the FreeCAD source code. More and more of the Git world is switch­ing to the new con­ven­tion to use “main” as their main branch name, instead of “mas­ter”. We think it’s a good time for FreeCAD to rename its main branch too.
The change will occur on Sun­day, Octo­ber 8th, 2023 around 20h00 UTC. If you are using a Git client, you will need to rename your local main branch as well, and recon­nect it to the cor­rect remote branch. Read more about that on https://forum.freecad.org/viewtopic.php?t=81651
If you don’t use Git, noth­ing will change for you!
