WIP Wednesday logo
  • Wan­der­erFan com­mit­ted sev­er­al fix­es and improve­ments to Tech­Draw, and edi271 con­tributed API exten­sions to the same work­bench and fixed a bug in VertexAtIntersection.
  • Pesc0 and chennes com­mit­ted fur­ther changes towards refac­tor­ing topo­log­i­cal nam­ing, patch­es include orig­i­nal code by realthun­der.
  • Pad­dle­Stroke improved angle con­straint ren­der­ing, imple­ment­ed draw­ing arc helpers for radius con­straints, and made sev­er­al more small improve­ments in Sketcher.
  • Syres916 improved sta­tus bar tooltips visibility.
  • br4243 con­tributed a fix for miss­ing let­ters when V‑carving a string in Path.
  • 3x380V fixed the Qt6 build by replac­ing the use of QReg­Exp with QRegularExpression.
  • kadet1090 added auto­mat­ic reset­ting of hor­i­zon­tal scrolling in the Pref­er­ences dia­log after the recent UI change.
  • mosfet80 updat­ed the Mesh work­bench to depend on smesh v7.7.1+.
  • marioalexis84 con­tributed sev­er­al fix­es to FEM.
  • Roy-043 fixed a bug in Draft where the Task pan­el check­box­es were repo­si­tioned by accident.
PR stats: In the week from Wednes­day, 10 Jan to Wednes­day, 17 Jan there were 31 pull requests merged, with a total code­base change of +2,173 / ‑607. We had an aver­age merged PR size of +70 / ‑20. 20 new pull requests were opened.
Issue stats: we closed 26 issues, and 29 new issues were opened. Over­all, 1,156 issues are cur­rent­ly open.
