With the release can­di­dates for ver­sion 1 appear­ing it’s a nice time to explore some of the new fea­tures and func­tion­al­i­ty that FreeCAD now offers. You can read a long detailed list of new fea­tures here, and it’s fair to note that many areas and work­bench­es of FreeCAD have received improvements.
The Sketch­er work­bench has numer­ous improve­ments, one of which is that we can now per­form mul­ti­ple oper­a­tions with­in a sin­gle sketch where­as in old­er ver­sions each oper­a­tion would require a dif­fer­ent sketch con­tain­ing geom­e­try. As a sim­ple exam­ple of this we’ve opened up a new project in the Part Design work­bench, cre­at­ed a new body and then cre­at­ed a sketch in the XY plane which takes us to a blank sketch in the sketch­er workbench.
Next we’ve quick­ly drawn an uncon­strained exam­ple sketch which con­tains a rec­tan­gle, a pair of cir­cles shar­ing the same cen­tre point and a hexa­gon. If we close the sketch, as usu­al, we are returned to the Part Design work­bench and we can see the sketch in the pre­view win­dow. Notice along the way that the new On View para­me­ter box­es appear as we draw allow­ing us to input dimen­sions as we sketch!
Using the con­trol key we can click each line of the rec­tan­gle in turn to select them all in the pre­view win­dow. Next click the Pad but­ton and in the dia­logue in the com­bo view check the “Reversed” radio but­ton so the pad is cre­at­ed below the sketch item in the Z axis. You should see that the Pad cre­at­ed is just the rec­tan­gle and the sketch is now tog­gled to non vis­i­ble inside the Pad item. Click the Pad item, high­light the sketch item and use the space bar to tog­gle it’s vis­i­bil­i­ty so we can see it again on top of the Pad we just cre­at­ed in the pre­view window.
We can now mul­ti select the 2 cir­cles we cre­at­ed in the sketch and use the Pad func­tion again to Pad the hol­low cylin­der ris­ing up from the rec­tan­gu­lar base. Like­wise we can per­form oth­er oper­a­tions, for exam­ple we can mul­ti select the lines cre­at­ing the hexa­gon and use the pock­et tool to cre­ate a hexag­o­nal hole extend down into the rec­tan­gu­lar pad.
Whilst all this was pos­si­ble in pre­vi­ous FreeCAD ver­sions it’s real­ly opti­mised work­flow allow­ing us to min­imise clut­ter in our hier­ar­chies and max­imise the use of sketch elements.
4 responses to “Tutorial: Multiple Operations from a Single Sketch”
  1. Applied Vehicle Technologies LLC Avatar
    Amaz­ing! Func­tion­al con­sol­i­da­tion like this will only increase effi­cien­cies across the board and speed up projects, espe­cial­ly big ones like ours. We might just have to onboard the RC here and give it a good workout!!
  2. Frank Avatar
    I am not sure if this fea­ture is good thing for updat­ing pre­vi­ous oper­a­tions. There is good prac­tise for edit­ing using the sim­plest sketch as pos­si­ble for only one fea­ture. At the begin­nig it is more work but in the end of project you have good and easy editable struc­ture of part (you can find eas­i­ly sketch­es for right feature)
  3. Michiel Bruijn Avatar
    Awe­some soft­ware. Thank you all very much for development!
  4. Mohammad Ebta Prakarsa Avatar
    This Sketch­er progress will be more effi­cient, and accurate.
    As we can reuse the exact lines with­out the need to recre­ate one.
    My sug­ges­tion: we can prob­a­bly simplify/speed up the selec­tion method using [click and drag] left­ward or right­ward (like exist­ing method in sketch­er mode).
    This will also be use­ful in posi­tion rela­tion review, just like in a Mas­ter Sketch.
Continue reading
