FEM: marioalexis84 rewrote meshing with Netgen to use Netgen’s Python bindings rather than a broken plugin in salomemesh. He also rewrote the way meshing with Gmsh is executed, so it’s now possible to cancel the entire process thanks to running it in a separate thread.
BIM: Roy-043, pinkavaj, and hoshengwei fixed several bugs including two in UI, and yorikvanhavre updated the workbench to support recently released IfcOpenShell 0.8.
TechDraw: WandererFan fixed a bug where the ‘Save a copy…’ command would be unavailable with an opened page, and benj5378 significantly improved the centering of labels inside balloons.
GUI: pinkavaj, qewer33 and benj5378 fixed various UI annoyances, and kadet1090 forced Qt6 to load OpenGL immediately, otherwise the first new document would be temporarily hidden. Please note: we are not planning to ship FreeCAD 1.0 built with Qt6, but we still need to fix these bugs.
Among other contributions:
- bgbsww and CalligaroV fixed several toponaming-related issues in Sketcher.
- hlorus and benj5378 fixed several issues in the new measurement tool, including one where the tool would get incorrect data from linked elements.
- bgbsww fixed a blocker issue in Part Design where a new sketch in a link would not open at the correct location.
- yorikvanhavre and Roy_043 fixed several minor bugs and regressions in Draft.
- furgo16 patched the legacy DXF importer to support importing dimensions.
- shaise improved the compatibility of the new mill simulator in CAM with less beefy GPUs.
PR stats: since the previous report, 52 pull requests have been merged, 38 new pull requests have been opened.
Issue stats: overall, there are 2051 open issues in the tracker, up by 53 from last week. 11 of them are v1.0 release blockers, up by 4 from last week.
2 responses to “WIP Wednesday 18 September 2024”
Great work! Thank you so much.
I found one bug in Techdraw (RC2):
When I try to add a horinzontal or vertical measurement between an edge and a (parallel) hole center line the following error message prevents this:
Can not make angle from parallel edges
This used to work before, I used it a lot in previous versions.
Sounds like a regression. Could you please report it to the tracker so that it isn’t forgotten?
