Part and Part­De­sign:
  • AIRCAP fixed anoth­er Loft issue and then a block­er where Pocket’s up-to-face option would work dif­fer­ent­ly (and incor­rect­ly at that) from v0.21.2.
  • mwgan­son fixed a bug where you wouldn’t be able to run Check­Ge­om­e­try on an X‑axis object when the “Too small edge” option is enabled, after expand­ing ori­gin object in Part Design.
Mea­sure: hlorus fixed 3 bugs includ­ing one release block­er where mea­sure­ments wouldn’t dis­ap­pear when reset was used in the task panel.
Assem­bly: Pad­dle­Stroke fixed a lag that would occur when drag­ging parts in an assem­bly with a lot of fixed parts.
FEM: marioalexis84 fixed anoth­er issue where flick­er­ing would occur between faces and wire­frame in FEM mesh view, it was more notice­able on curved sur­faces and using flat col­or for the wireframe.
Tech­Draw: Wan­der­erFan fixed 7 minor issues (1 of them not report­ed to the tracker).
CAM: shaise dropped the pre­vi­ous code for Screen Space Ambi­ent Occlu­sion shaders in favor of one that is under the MIT license for license compatibility’s sake.
GUI: Syres916 added a workaround for Qt6 and its OpenGL widget’s mis­be­hav­ior, and hyari­on con­tributed a fix towards elim­i­nat­ing anoth­er block­er where the appli­ca­tion would crash on macOS.
Fur­ther BIM and core fix­es came from NomAnor, ours­land, hyari­on, bgb­sww, and wwmayer.
PR stats: since the pre­vi­ous report, 21 pull requests have been merged, 33 new pull requests have been opened.
Issue stats: over­all, there are 2136 open issues in the track­er, up by 48 from last week. 12 of them are v1.0 release block­ers, up by 6 from last week.
3 responses to “WIP Wednesday 2 October 2024”
  1. Hynek Avatar
    Hynek
    thx!!!
  2. Keith G Avatar
    Keith G
    From a new user MANY Thanks to ALL the con­trib­u­tors who have worked on what is becom­ing a GREAT soft­ware product!
  3. Leandro Lopes Avatar
    Leandro Lopes
    I am learn­ing the soft­ware so I can use the Bim work­bench. Lov­ing the speed it finaly is get­ting on fix­es and devel­op­ment! Thanks guys, you can count on some coffe from me.
