Sketch­er:
  • AjinkyaDa­hale con­tributed round 3 of the refac­tor­ing project.
  • mosfet80 cleaned up anoth­er part of Sketcher’s code.
  • web­nard fixed a bug pre­vent­ing FreeCAD from fil­ter­ing named constraints.
Part­De­sign:
  • alfrix redesigned the hole cut pan­el and imple­ment­ed the auto find­ing of the clos­est size when chang­ing thread stan­dards from Met­ric to Metric-Fine.
  • jffmichi fixed a crash where FreeCAD would crash when open­ing a file with a met­ric hole.
Draft: Roy_043 intro­duced a uni­form scal­ing option for Clone scal­ing, made arrays explod­able, imple­ment­ed an “Add to lay­er” com­mand (and grouped all three “Add” com­mands in the menu), and fixed a cou­ple of bugs.
BIM:
  • yorik­van­havre upgrad­ed the BIM Project Man­ag­er tool to sup­port Native IFC projects.
  • Roy_043, furgo16, and Syres916 fixed var­i­ous bugs.
Tech­Draw: benj5378 imple­ment­ed a new fea­ture that allows users to align the vertical/horizontal axis of a view to match an edge.
FEM: col­in­Rawl­ings imple­ment­ed a new fea­ture for work­ing with mesh group solids; now when the select­ed face or edge belongs to mul­ti­ple solids, FreeCAD will show a pop­up to allow the user to select which sol­id they wish to add.
Among oth­er changes:
  • michaesc added the poly­car­bon­ate mate­r­i­al phys­i­cal prop­er­ty to the new mate­ri­als system.
  • Lar­ry­Woest­man con­vert­ed refac­tored post­proces­sors to a new, more object-ori­ent­ed API.
  • Flast improved DXF import per­for­mance by reduc­ing calls of transcode (up to 5% gain on cer­tain projects).
  • karliss intro­duced a workaround for trans­paren­cy issues on Wayland.
  • xtemp09 fixed a crash in Assembly.
Addi­tion­al fix­es were con­tributed by her­bkoni, tri­tao, benj5378, hyari­on, chennes, Phone­Droid, GS-GOAT, Syres916, ours­land, mwgan­son, mosfet80.
PR stats: since the pre­vi­ous report, 50 pull requests have been merged, and 32 new pull requests have been opened.
Issue stats: over­all, there are 2568 open issues in the track­er, up by 15 from last week.
