Sketch­er: refac­tor­ing by AjinkyaDa­hale, fix­es by chennes and ElementW.
Part­De­sign: alfrix moved the selec­tor for Hole base pro­files to the top of the Task panel.
Tech­Draw:
  • Pad­dle­Stroke fixed a bug where a hatch would not be claimed by a view, then anoth­er bug in the dec­o­rate line code, and removed a lim­i­ta­tion where the Lock/Unlock com­mands would only work on a sin­gle view.
  • benj5378 fixed a bug where the face col­or for view would not work.
CAM:
  • Lar­ry­Woest­man added com­mand line argu­ments for coolant, machine-spe­cif­ic com­mands, and end-of-line characters.
  • tarman3 added a but­ton to reset the cam­era view to the new Sim­u­la­tor. He also added a pos­si­bil­i­ty to cre­ate PathShape object inside Job with Tool Con­troller; this allows using some mod­i­fiers, array and path simulator.
  • jffmichi fixed a cou­ple of bugs.
BIM:
  • tetek­toza fixed the map­ping to weight dur­ing the IFC Quan­ti­ties assignment.
  • furgo16 fixed a bug and added the Off­set input to the Wall cre­ation task panel.
FEM:
  • NewJok­er added sev­er­al new VTK glyph types for the new Glyph fil­ter: Cone, Cylin­der, Line, and Sphere.
  • marioalexis84 added sup­port for VTK < 9.1 in the cal­cu­la­tor filter.
GUI:
  • alfix fixed a cou­ple of issues.
  • The big new fea­ture com­ing from kadet1090 are the new inter­ac­tion hints in the sta­tus­bar, sim­i­lar to what you get in Blender and Dune3D:
Among oth­er changes:
  • Var­i­ous fix­es in Draft by Roy_043.
  • hlorus fixed a cou­ple of bugs in the Mea­sure tool.
  • tri­tao and kadet1090 fixed a cou­ple in the Mate­ri­als code.
Addi­tion­al improve­ments and fix­es were con­tributed by chennes, sasobadov­inac, luz­paz, pieter­hi­j­ma, Flast, adri­an­in­saval, jffmichi, 3x380V, xtemp09, mosfet80, trita0, hyari­on, and davesrocketshop.
PR stats: since the pre­vi­ous report, 52 pull requests have been merged, and 37 new pull requests have been opened.
Issue stats: over­all, there are 2896 open issues in the track­er, up by 44 from last week.
4 responses to “WIP Wednesday, 21 May 2025”
  1. Stefan Hertweck Avatar
    Stefan Hertweck
    Hel­lo Aleksandr,
    if not already done, it would be good to pro­vide a link to the issue track­er (list) so that moti­vat­ed pro­gram­mers can check out where they can con­tribute. In addi­tion, the list should be prioritized.
    What do you think?
    Ste­fan (FreeCAD Forum aka MTronic)
    1. hacker Avatar
      hacker
      Moti­vat­ed pro­gram­mers should have no dif­fi­cul­ty find­ing that list. Hint: github
  2. bug reporter Avatar
    bug reporter
    Hel­lo
    Have the refac­tor­ing by AjinkyaDa­hale and the fix­es by chennes and Ele­men­tW been merged yet?
    The devel­op­ment ver­sion released on 26 May 2025 has sev­er­al issues with the Trim edge tool in the Sketch­er Workbench.
    FreeCAD_weekly-builds-41866-conda-Windows-x86_64-py311.7z
    1. Aleksandr Prokudin Avatar
      Aleksandr Prokudin
      All the changes you see men­tioned here are merged pull requests. I bare­ly ever cov­er WIP patch­es in the queue.
      The gen­er­al loca­tion of inter­im builds is about to change. We haven’t yet announced it, but please see if this works bet­ter for you: https://github.com/FreeCAD/FreeCAD/releases/tag/weekly-2025.05.26
Continue reading
