Sketch­er: Pad­dle­Stroke fixed two regres­sions, includ­ing one where Sym­me­try didn’t work on arcs with con­strained centers.
Assem­bly: Pad­dle­Stroke fixed 5 issues and added visu­al iso­la­tion of joint com­po­nents when cre­at­ing or edit­ing a joint.
CAM:
  • tarman3 fixed three issues in the LeadI­nOut dress-up and a bug in the old CAM simulator.
  • Con­nor fixed a topon­am­ing issue.
GUI:
  • sliedes patched the code to request 24-bit col­or pre­ci­sion where pos­si­ble, as Qt would set­tle for RGB565 in some sce­nar­ios, so you’d see band­ing in gra­di­ents in the 3D view.
  • Rexbas fixed the con­flict between the Trans­form tool and the Open­SCAD nav­i­ga­tion style.
  • hyari­on added a selec­tor to the sta­tus bar’s con­text menu to tog­gle quick mea­sure and input hints.
Oth­er changes:
  • Wan­der­erFan, johndoe2323, and aqeel13932 fixed sev­er­al issues in TechDraw.
  • Roy_043, paullee0, and furgo16 fixed 7 issues in BIM.
  • Phone­Droid added miss­ing SPDX license iden­ti­fiers to source code files.
Addi­tion­al improve­ments and fix­es were con­tributed by mar­cus­pol­lio, chennes, Syres916, pieter­hi­j­ma, mrpilot2, pyro9, ipatch, furgo16, ifo­han­croft, and PhoneDroid.
You’ll notice two new fea­tures despite the fea­ture freeze. The PRs were select­ed for inclu­sion before the cut-off. How­ev­er, the patch­es need­ed a minor tweak­ing before the main­tain­ers could merge them.
Trans­la­tions are now auto­mat­i­cal­ly synced between GitHub and Crowdin every Sunday/Monday mid­night, thanks to a CI patch by OPGL.
PR stats: since the pre­vi­ous report, 56 pull requests have been merged, and 23 new pull requests have been opened.
Issue stats: over­all, there are 2969 open issues in the track­er, up by 15 from last week. 28 known release block­ers remain unfixed for v1.1, down by 2 from last week.
