Sketcher
- wwmayer added two commands, Delete All Constraints and Delete Filtered Constraints (PR#29993, cherry-picked by maxwxyz).
- maxwxyz grouped Polyline and Line tools by default (PR#30347). He also brought back the original G,M shortcut for the Polyline tool (PR#30395) and re-added hints for that tool (PR#30344).
- xorza patched the code so that when you long-press an edge shared by two internal faces, the clarify selection menu will now list both adjacent faces instead of only one (PR#29159).
- PaddleStroke fixed tool shortcuts (PR#30348).
- Reqrefusion patched the Arc tool so you can give an arc an angle by clicking while the angle tool is selected. (PR#29679).
CAM
- tarman3 fixed regressions in DressupTag (PR#30267) and the freeze toggle (PR#30240), added checks for tolerance error and edges length (PR#29593), and patched Profile so you can add models as Base without subselection (PR#24194).
- Connor9220 added the linking generator to the Engrave and Deburr operations so that the safe height is used for linking moves instead of the clearance height (PR#29959).
Other changes
- Roy_043 fixed a BSpline regression in Draft (PR#29858).
- maxwxyz made it possible to use the Center of mass / Centroid mode for Links and Part containers in the Transform tool (PR#30208).
- PaddleStroke fixed the extra grounded joint in Assembly appearing after reopening a file (PR#30314).
- WandererFan improved TechDraw to allow horizontal/vertical dimensions between circle edges (PR#30379).
- drwho495 reimplemented a few changes from the RealThunder’s fork to improve toponaming support for addons, such as SheetMetal (PR#24632).
Additional improvements and fixes were contributed by andershol, awgrover, Lgt2x, maxwxyz, PaddleStroke, rehan-ahmed-aix, Roy_043, and semhustej.
Activity stats
PR stats: since the previous report, 31 pull requests have been merged, and 47 new pull requests have been opened.
Issue stats: overall, there are 3464 open issues in the tracker, up by 22 from last week.
One response to “WIP Wednesday, 27 May 2026”
Nice Work Team! Always look forward to the weekly updates. Keep it up!
