Draft
maxwxyz added input hints to the statusbar for the Edit tool and modification tools (PR#30436 and PR#30437).
Sketcher
- wmayer fixed several memory leaks (PR#29986, cherry-picked by maxwxyz), added input hints to the Dimension tool (PR#30630) and the B‑Spline tool (PR#30628).
- PaddleStroke fixed a bug where the new polyline undo with R would keep undone segments as real geometry (PR#30630) and another bug where it was impossible to start a polyline at the bottom of a circle (PR#30666).
- Reqrefusion patched the autoconstraint to make point-on-line constraints applicable along lines, not just above lines (PR#30332).
- Lokestrom added on-view parameters to arcs of ellipse, hyperbola, and parabola (PR#29318).
- ItSaulGoodMan patched the Trim tool to preserve ellipses’ internal geometry (PR#30138).
- matthiasdanner fixed a bug where the sketch couldn’t be exited with Escape when the bottom overlay is hidden (PR#29873).
Part and PartDesign
- ItSaulGoodMan fixed the compound deletion to prevent orphan objects from being left behind (PR#29856).
- PaddleStroke moved the linear and polar pattern logic out of PartDesign to make it reusable across the application (PR#30417). This is part of his grant work to refactor pattern tools.
- maxwxyz fixed a toponaming occurring upon deleting a feature (PR#30403).
- depthoffocus fixed Unicode filename issues in Loft and Sweep (PR#29728).
- tritao ported the remaining Gui and PartGui overlay/highlight nodes off direct legacy OpenGL calls into Coin scenegraph geometry/state (PR#29030). This is part of his grant work.
Assembly
PaddleStroke made the Insert Part command respect the active selection (PR#30041). He also fixed several bugs:
- where subassembly flexible joints would be ignored when applying a joint to a rigid subassembly, and then turning it flexible (PR#30679).
- where a joint would become visible again after selection by a user and then hide again (PR#30598).
- where Insert New Part wouldn’t create the specified joints (PR#30600).
- where FreeCAD would crash on double-clicking an assembly link (PR#30037).
CAM
The big news here is the patch by sliptonic to add workplane-driven 3+2 (indexed) toolpath generation across most CAM ops: Profile, Pocket/PocketShape, MillFacing, Drilling, CircularHole, Engrave, Vcarve, Adaptive, and Deburr (PR#30106).
Additional changes:
- tarman3 fixed wire checks when the start/target positions touch the model (PR#30385).
- Dimitris75 improved the Step Over consistency across operations (PR#27038).
BIM:
- tritao fixed a regression in sketch-based walls where some left-aligned wall traces could lose large parts of their shape during base face generation (PR#29703).
- maxwxyz improved the BIM Views Manager user interface and optimized the new level creation workflow (PR#30420).
- Roy_043 fixed import issues that occurred when using the Strict IFC mode (PR#30001) and the fills of shaft-like objects in Draft_Shape2DView (PR#29539).
Other changes
- wmayer fixed B‑spline curve fitting in Reverse Engineering (PR#29985, cherry-picked by maxwxyz).
- WandererFan fixed a bug in TechDraw where a shallow curve would be depicted as a line (PR#30388).
- marioalexis84 improved the error message in FEM for cases when solvers run from the task panel without a mesh or with more than one mesh (PR#29186).
- pieterhijma a context menu item in the Property View that allows you to report in which expressions these properties are used (PR#23989).
- Dan-Crane fixed UTF‑8 encoding for non-ASCII names in the Expression Editor and property links (PR#29875).
- tritato added navigation controls for locked view orientations (PR#29200).
Additional improvements and fixes were contributed by chennes, ElementW, ItSaulGoodMan, Lgt2x, luzpaz, maxwxyz, mnesarco, PaddleStroke, and ypsvlq.
Activity stats
PR stats: since the previous report, 62 pull requests have been merged, and 35 new pull requests have been opened.
Issue stats: overall, there are 3470 open issues in the tracker, same as last week.
