Sketcher
  • maxwxyz added sta­tus­bar hints to pat­tern tools (PR#31536) and increased the con­trast of the default face col­or (PR#31369).
  • Pad­dle­Stroke fixed the Poly­line parallel/perpendicular helper dis­ap­pear­ing after an arc seg­ment (PR#31588), a Poly­line snap­ping bug (PR#30579), and anoth­er bug where the Move/Array trans­form tool would break con­straints (PR#30507). He also added a sym­met­ric mode to the Rotate tool (PR#30747).
  • xorza fixed a regres­sion relat­ed to pre­serv­ing lega­cy inter­nal face nam­ing in old­er doc­u­ments (PR#31117).
  • ipatch fixed a bug where con­straints could be lost when split­ting an edge (PR#31216).
Part and PartDesign
  • alfrix fixed the M26 thread miss­ing from Hole para­me­ters (PR#30770).
  • Pad­dle­Stroke fixed sev­er­al bug in pat­tern tools (PR#30851 and PR#31496).
  • maxwxyz fixed two issues with boolean place­ment preser­va­tion (PR#30575).
TechDraw
ryankem­brey improved the selec­tion of leader lines (PR#30986) and made it pos­si­ble to open the task pan­el by dou­ble-click­ing on a view or a pro­jec­tion group in the page (PR#30797).
BIM
  • maxwxyz fixed a regres­sion where chang­ing ele­va­tion in BIM Views Pan­el wouldn’t change the lev­el posi­tion (PR#31433). He also added the Draft_Edit com­mand to the BIM WB menu and tool­bar to the 2D mod­i­fy tools, so that it’s pos­si­ble to edit base­less walls and oth­er base objects with­out the need to switch work­bench­es (PR#31538).
Other changes
  • tri­tao made it pos­si­ble to set save grid set­tings as doc­u­ment prop­er­ties, so that reopen­ing a design on anoth­er com­put­er will pre­serve the intend­ed grid con­text (PR#30696).
  • tarman3 fixed a bug where the Inspec­tor would not open in cer­tain cir­cum­stances (PR#30897).
  • marioalexis84 fixed Elmer mechan­i­cal equa­tions for 2D cas­es (PR#31610).
  • pieter­hi­j­ma added a workaround for STEP export regres­sion in Open­Cas­cade 8 (PR#31067).
  • tsaaris­to improved image cal­i­bra­tion by allow­ing image rota­tion to align the cal­i­bra­tion line to the near­est 45° (PR#30755).
Addi­tion­al improve­ments and fix­es were con­tributed by chennes, Ele­men­tW, grae­lo, HonakerM, ipatch, j‑hewett, Lgt2x, maxwxyz, mosfet80, NewJok­er, Pad­dle­Stroke, tri­tao, and wmayer.
Activity stats
PR stats: since the pre­vi­ous report, 51 pull requests have been merged, and 49 new pull requests have been opened.
Issue stats: over­all, there are 3502 open issues in the track­er, down by 6 from last week.
One response to “WIP Wednesday, 29 July 2026”
  1. Peter Kelly Avatar
    Peter Kelly
    You guys are like a steam-train roar­ing along- heaps of (men­tal) pow­er, heaps of momen­tum, and plen­ty of appre­cia­tive pas­sen­gers. Unlike the com­mer­cial oppo­nents, you keep inno­vat­ing because you have few polit­i­cal rea­sons to total­ly be your­selves:- keep it up.
    Well done and cheers, p.
