An incredibly useful tool in FreeCAD is the Curved Array tool found in the optional “Curved Shapes” workbench add on. This tool is useful for creating curved geometry from a generated collection of spaced profile sketches formed, adapted and constrained by other curved paths in sketches.
In the above image you can see a small boat hull which has made with the curved array tool. If you are more used to more standard Part and Part Design workbench approaches, you might find it quite tricky to imagine how these parts are made.
To begin we need to install the Curved Shapes workbench. From anywhere in FreeCAD left click on the “Tools” dropdown menu and left click on “Addon Manager”. Use the search function to find the Curved Shapes workbench and click to install it. Once installed close the Addon Manager dialogue and you will be prompted to restart FreeCAD. Once FreeCAD is reopened let’s click to create an empty project and move to the part workbench.
The first part we are going to replicate is this part. To use the Curved Array tool we essentially need 3 sketches in 3 different planes. One sketch can be considered a profile which will be swept along paths/curves and replicated an adjustable amount of times.
So to begin lets, in an empty project, move to the sketcher workbench and create a sketch in the XY plane. We’ve used the polyline tool to create half of the sketch and then used the mirror Mirror tool to create a matching half. We aren’t worried about constraining sketches in this tutorial, but obviously you may do so in your project.
With our XY plane sketch finished we can close it. Before making the next sketch we’ll note that we are going to consider the XY sketch our profile sketch that will be arrayed using the other sketches. Let’s next click to make a new sketch selecting to make this sketch in the XZ plane.
We can see our earlier XY sketch, let’s use the “External Projection” tool to add reference geometry selecting the outermost points of the XY sketch, or selecting the first arcs attached to the X axis. This gives us a reference geometry at the widest points of our XY sketch. You can make it easier to see these point by rotating the XZ sketch view slightly.
Next we can use the polyline tool to create a couple of arcs connecting one of the outer reference points of the XY sketch up to the Z axis in a curve. We can then again use the Mirror tool to create matching geometry for the other side.
We can then close the XZ sketch and finally make a new sketch in the YZ plane. Use the “External Projection” tool to import reference geometry for the tallest points of the 2 preceding sketches we made. Then in turn use the polyline tool to create some arcs connecting the outermost points on the Y and Z axis. Finally we need in this sketch to also draw a vertical line down from the tip of the Z axis geometry to the datum point. You should end up with a set of sketches looking similar to the image below.
To then create a Curved Array we need to move to the “Curved Shapes” workbench. It’s important that we then select all three sketches in the correct order. Left click on our original sketch in the model tree, then use control and left click to select the sketch001 and then the sketch002. Then click the “Curved Array” tool icon.
A “Curved Array” item will be created and, in standard fashion, your original sketches will be nested under this item drop down. Left click on the “Curved Array” item to see the items settings in the data tab. You possibly won’t see any curved array at this point and may need to click check the “Distribution Reverse” checkbox. You should then see (if you couldn’t previously) some elements added to our sketches which are copy elements of our original sketch, scaled in an array constrained by the other sketches. As in the image below.
In the curved array data tab we can now also increase the number of “items” this adds complexity to the array, but as the number of items increases the overall object has higher definition and may represent our desired object more closely. In the image below we have set the number of items to 14.
Finally for this quick exploration, we can also check the “Solid” checkbox in the curved array data tab to create a solid from our array. To then neaten our live preview we can also toggle the transparency of our original sketch items using the usual method of selecting the sketch item in the file tree and toggling visibility.
Leave a Reply
