WIP Wednesday 5 June 2024
This week, FreeCAD has entered fea­ture freeze for upcom­ing v1.0. This means no new patch­es adding fea­tures will be merged until the new ver­sion is released.
Major changes this week:
Sketch­er:
  • @kadet1090 fixed a bug where col­ors of sketch­es would­n’t get updat­ed when a user changed theme preferences.
  • @howie‑j added a pref­er­ence tog­gle for choos­ing the pre­ferred method of con­strain­ing cir­cles with on-view para­me­ters (the new float­ing input wid­gets): auto­mat­i­cal­ly, by diam­e­ter, or by radius.
  • @wwmayer refac­tored the Sketch Analy­sis code.
BIM: @Syres916 and @yorikvanhavre con­tin­ued clean­ing up the com­bined Arch/BIM/NativeIFC workbench.
Mate­ri­als: @davesrocketshop improved the use of the Sha­peAp­pear­ance prop­er­ty for the Part work­bench, as well as UI ele­ments for set­ting object appear­ance. He also laid the foun­da­tion for future tex­ture sup­port and added API for inher­it­ing a material.
CAM: @sliptonic added machin­abil­i­ty mate­r­i­al mod­el, a cou­ple of mate­ri­als, and a but­ton in the job dia­log to assign a mate­r­i­al. So when you try to assign a mate­r­i­al in the CAM work­bench now, you will get a list of only machin­able mate­ri­als. The san­i­ty report has been updat­ed to dis­play the sur­face speed for assigned mate­ri­als. This is the bare min­i­mum of sup­port for the new mate­ri­als sys­tem in CAM.
VarSets got two patch­es by @pieterhijma. The first one pro­vides a GUI com­mand to cre­ate vari­able sets and it presents you with a dia­log to add prop­er­ties. The sec­ond one allows users to direct­ly add prop­er­ties to vari­able sets from with­in the expres­sion input dialog.
Among oth­er changes:
  • @bgbsww did fur­ther cleanup in the new topon­am­ing code.
  • @PaddleStroke fixed sev­er­al bugs in new snap­ping and smart dimen­sions code.
  • @maxwxyz con­tributed small UI improvements.
PR stats: In the week from Wednes­day, 29 May to Wednes­day, 5 June there were 53 pull requests merged. 46 new pull requests were opened.
Issue stats: we closed 44 issues, and 55 new issues were opened. Over­all, 1,681 issues are cur­rent­ly open.
Continue reading
