FreeCAD 1.1 is now out, maintainers will keep backporting some changes from the main development branch to the 1.1 branch for future bugfix releases.
Sketcher:
- wiljam144 changed the default value for “Scale upon first constraint” from “Always” to “When no scale feature is visible” (PR#27955).
- Bojan9597 fixed an issue where toggling construction lines for geometries like B‑spline would result in an error message (PR#28081).
- PaddleStroke fixed several bugs:
Part and PartDesign:
- alfrix fixed a bug where cosmetic threads are invisible when not using a sketch for the holes (PR#28461).
- paragforwork fixed a bug where copying an argument of transformShape would have no effect (PR#28299).
Assembly: PaddleStroke fixed a bug where double-clicking would be broken when a linked assembly is in an external file (PR#28235).
FEM:
- marioalexis84 contributed numerous changes, including these:
- captain0xff fixed broken CCX Result display scale (PR#28012).
CAM:
- davidgilkaufman fixed unnecessary ToolController recomputes (PR#28478).
- jffmichi fixed operations needing recompute after post-processing (PR#27992).
- sliptonic pushed another patch towards using the machine addon in the machine editor (PR#28405).
- lots of changes from tarman3, including these:
- Updated Helix: StartRadius is now called OffsetInnerRadius and can be positive or negative; OffsetExtra is now OffsetHole and can apply to the outer diameter of the hole only (PR#21971).
- Patched Profile to process subshapes independently (PR#27458).
- Added RetractThreshold option to avoid unnecessary retractions in Pocket and Profile (PR#21738).
- Added new LineZFollow style for LeadInOut (PR#27986):
TechDraw:
- captain 0xff fixed a regression where extending the circle centerline was changing its style (PR#28585).
- paragforwork fixed a bug where undo would remove a TechDraw page, but the page tab would stay open (PR#27994).
- rehan-ahmed-aix fixed inconsistent cosmetic thread diameters in the bottom view (PR#27784).
- dkleszyk made section line font, font size, and arrow size configurable (PR#27521).
BIM/Arch:
- Roy-043 fixed a bug where creating window types produces errors (PR#27420). He also fixed a crash caused by grouped commands (PR#28407) and another bug where the cut stays active in the 3D view when an active action plane is deleted (PR#28432).
- paragforwork fixed linked Arch axis losing bubbles and text in TechDraw DraftView (PR#27985).
- czarflix fixed the loading of IfcLogical material layers (PR#28591).
- furgo16 fixed the sun path arc (PR#28498).
Mass properties: this is a brand new feature added by MortenVajhoj to measure volume, mass, total density, surface area, COV, COG, and inertia.
Bojan9597, PaddleStroke, davesrocketshop, timpieces, hyarion, ayushishuklaME, czarflix, sliptonic, theo-vt, paragforwork, Krrish777, rehan-ahmed-aix, timpieces, marcuspollio, theosib, wwmayer, 3x380V, marioalexis84, captain0xff, maxwxyz, ipatch, alfrix, Dinis-Esteves, filippor, jffmichi, PhoneDroid, chennes, leoheck, Lgt2x, ghatoleaakruti, andershol, MortenVajhoj contributed additional improvements and fixes.
PR stats: since the previous report, 100 pull requests have been merged (including backports to the v1.1 branch), and 59 new pull requests have been opened.
Issue stats: overall, there are 3357 open issues in the tracker, up by 25 from last week.
One response to “WIP Wednesday, 25 March 2026”
I see that the version of FreeCAD on Flathub is still 1.0.2. Any idea when that will be updated to 1.1?
