Draft: tetek­toza imple­ment­ed a 1‑axis mode in Ortho Array to mod­i­fy only one axis at a time.
Sketch­er:
  • tetek­toza made it pos­si­ble to reset an on-view parameter’s state by press­ing backspace.
  • theo-vt con­tributed sketch autoscal­ing that trig­gers a scale action when there is a sin­gle-dimen­sion con­straint in a sketch and its datum is edit­ed to avoid break­ing the over­all shape of the sketch.
  • Var­i­ous oth­er fix­es and small­er improve­ments con­tributed by lon­grack­slabs and tetektoza.
Part­De­sign: maxwxyz improved the new Trans­form task pan­el to allow lim­it­ing the trans­form to trans­la­tion only, rota­tion only, or spec­i­fy­ing a com­bi­na­tion of all indi­vid­ual com­po­nents. This allows to align an object to a tar­get, with­out mov­ing or rotat­ing it, or lock move­ment in cer­tain axes.
FEM: rhabacker added a but­ton and a con­text menu entry to clear all ref­er­ences in all con­straints dialogs.
BIM:
  • Roy-043 fixed an issue where a roof object would not cor­rect­ly end at the top and con­tin­ue fur­ther. He also improved unit han­dling in the Roof task panel.
  • Fix­es and small­er improve­ments by Syres916, furgo16, and paullee0.
CAM:
  • Harvie added the 3.175mm milling bit to the default tool library.
  • knip­knap con­tributed sev­er­al fixes.
GUI:
  • kadet1090 improved the group­ing of set­tings on the Selec­tion page in Preferences.
  • Rexbas improved the ortho­graph­ic cam­era rota­tion sta­bil­i­ty so that the rota­tion cen­ter wouldn’t move while rotating.
  • wwmay­er con­tributed a Siemens NX nav­i­ga­tion style.
  • Var­i­ous fix­es by dzid26, alfrix, maxwxyz, kadet1090, 3x380V.
I/O:
  • rhabacker patched the OBJ importer to insert import­ed objects into a new group in the top lev­el of the project tree to avoid flood­ing it.
  • totake0224 fixed sev­er­al SVG import­ing bugs.
Among oth­er changes:
  • Wan­der­erFan fixed sev­er­al issues in TechDraw.
  • wwmay­er added a task dia­log for the blend curve in the Sur­face workbench.
  • wwmay­er and godi­ard fixed sev­er­al issues in Spreadsheet.
Addi­tion­al improve­ments and fix­es were con­tributed by Roy-043, luz­paz, maxwxyz, wwmay­er, chennes, 3x380V, ours­land, furgo16, tri­tao, Syres916, sasobadov­inac, zbynek­win­kler, and mosfet80.
PR stats: since the pre­vi­ous report, 57 pull requests have been merged, and 45 new pull requests have been opened.
Issue stats: over­all, there are 2928 open issues in the track­er, up by 18 from last week.
One response to “WIP Wednesday, 11 June 2025”
  1. toremato23 Avatar
    thanks !
