Draft: Roy-043 spec­i­fied units of spin­box­es in UI files for arrays and ShapeString and made minor improve­ments in the OrthoAr­ray task panel.
Sketch­er:
  • theo-vt and tetek­toza fixed a cou­ple of issues.
  • tetek­toza also patched the code to show geom­e­try lines above constraints.
  • lon­grack­slabs con­tin­ued adding con­tex­tu­al input hints to edit tools.
  • maxwxyz patched Sketch­er to show the dimen­sion­al name by default.
Part­De­sign:
  • Pad­dle­Stroke brought over a fea­ture from RealThun­der’s fork, that adds faces to closed wires of sketch­es and thus lets the user select the faces they want to extrude.
  • dav­e­tanana added 1 3/16 16 thread­ed drill hole diam­e­ter to the Hole tool.
BIM: Roy-043, furgo16, Syres916, and tetek­toza, and maxwxyz fixed sev­er­al bugs.
CAM: knip­knap patched the work­bench to show abbre­vi­a­tions on each label to match the input val­ue to the shape image on the UI.
Tech­Draw: ryankem­brey added spac­ing pre­view, so now each time a val­ue is adjust­ed, the view is updat­ed on the page instantly.
I/O: furgo16 renamed “Group lay­ers into blocks” into “Merge lay­er and con­tents into blocks” in the DXF loader options and fixed the han­dling of non-stan­dard 8859_1 encodings.
Addi­tion­al improve­ments and fix­es were con­tributed by wmay­er, hyari­on, chennes, furgo16, tetek­toza, Syres916, Roy-043, benj5378, alfrix, kadet1090, captain0xff, and 3x380V.
PR stats: since the pre­vi­ous report, 39 pull requests have been merged, and 42 new pull requests have been opened.
Issue stats: over­all, there are 2921 open issues in the track­er, down by 7 from last week.
Else­where in the com­mu­ni­ty, Sar­goDe­v­el released a new ver­sion of their Cables workbench.
Some of the inter­est­ing changes are:
  • Wire­Flex can now take dif­fer­ent shapes based on the same points: poly­line or bspline.
  • Intro­duced col­ored mark­ings of attached ver­tices in WireFlex.
  • Added Com­pound­Path and Cable­Con­duit objects that enable the cre­ation of com­plex bundles.
  • Undo/redo sup­port.
  • Key­board shortcuts.
2 responses to “WIP Wednesday, 18 June 2025”
  1. jömk Avatar
    jömk
    If I under­stand the faces-from-wire patch cor­rect­ly, this is huge! So you can make one sketch with sev­er­al closed areas and one-click select dif­fer­ent faces to extrud­de inde­pen­dent­ly? Instead of hav­ing to con­trol click all the indi­vid­ual edges around it. Could also be used with e.g. sub­shape­binders to add an off­set quick­ly and selec­tive­ly to parts of a sketch, for things like clearances 😀
    Awe­some job, all of you!
  2. Architect Avatar
    Architect
    Thanks Tetek­toza, this should make sketch­es far more clear.
