Sketcher
- ipatch added face highlighting when using the external projection tool (PR#29826).
- PaddleStroke fixed the perpendicular autoconstraint (PR#30568) and on-view parameter focus issues (PR#30414).
- FlachyJoe fixed two toponaming-related issues (PR#30467).
- tritao restored cancellation behavior when Esc is pressed inside an active on-view parameter (PR#30445) and improved Sketcher preselection when constraints, points, and edges overlap in the sketch edit mode (PR#30412).
Part and PartDesign
- tritao improved face highlighting for cases where one logical element can span multiple faces (PR#29197).
- wmayer fixed copying face, edge, and vertex colors in the Mirroring dialog (PR#30435, cherry-picked by maxwxyz).
- slendidev fixed a mirroring crash (PR#29737).
CAM
- petterreinholdtsen extended the post-processor test mock code so that the Tool and ToolController behave more like the real thing, and the mock code can work with the extended OpenSBP post-processor (PR#27515).
- awgrover fixed the annotation building (PR#30217) and added the Probe operation’s filename as an annotation (PR#30141).
- tarman3 was on a roll with 14 out of 21 merged PRs, including these: buttons to enable/disable and clear all tags in DressupTags (PR#29849), new Offset option in DressupPathBoundary (PR#29638), selecting inner edges of selected horizontal face in SelectLoop (PR#26786), a fix for step down not taken into consideration in Vcarve (PR#30489), new Points pattern type in the Array op (PR#23606).
BIM
- Roy_043 fixed numerous issues: Multi-Material Definition task panel not working with the Building US unit schema (PR#30518), Arch_RemoveShape not working properly (PR#28929), TechDraw_ArchView not respecting Clip for the hidden geometry (PR#29819), and more.
- Bojan9597 fixed ArchView fill color not showing for MultiMaterial objects (PR#30131).
Other changes
- Roy_043 decoupled Continue and Chain modes in Dimension so that non-linear dimensions work as expected (PR#29744).
- tritao made recovery snapshot writes less frequent, which helps with large documents (PR#29693).
- matthiasdanner fixed cached label names not deleted on rename in the object tree, so that label names no longer in actual use could be used for something else (PR#29915).
- wmayer fixed the recursive removal of objects (PR#30434, cherry-picked by maxwxyz).
- PaddleStroke improved the navicube: the menu is now a shape that looks like a menu, there’s a home button now, and ‘rotate back to forth’ is arrow-shaped now rather than a nondescript dot (PR#29338).
Additional improvements and fixes were contributed by alopes0905, chennes, eolder, greg19, ipatch, Lgt2x, Lokestrom, maxwxyz, and pieterhijma.
Activity stats
PR stats: since the previous report, 56 pull requests have been merged, and 40 new pull requests have been opened.
Issue stats: overall, there are 3470 open issues in the tracker, up by 6 from last week.
